Cheapest And Best Swap For '97 Ex
Discussion in 'HYBRID -> EG-EK / DC' started by BrainFood, Jan 22, 2003.
  1. BrainFood
    BrainFood Junior Member
    Should I look into just getting a used d16 or should I swap in a b series motor, I was thinking about a b18b how much am I looking to spend total to put it in I will do all my own work so just parts? any other cheap swaps I should look into. the d series trans needs to be replaced with a b series trans doesnt it?
  2. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    what are you looking for in this swap. If you want a turbo application get a B18, but if you want an all motor car, check out the b16a2 they will be the best bet for fast car on a budget.
    Peace
  3. BrainFood
    it will be kept n/a and it doesnt need to be terriibly fast either just a little more power than stock and would like to go to something dohc, the b16a2 is the si motor right? how much and where can I find one, do I need ecu/trans also
    thx bryan
  4. sweetcivicinlex
    sweetcivicinlex Member
    VA
