Check engine light not staying on
Discussion in 'General Tech and Maintenance' started by hondaflr, Jun 14, 2004.
  1. hondaflr
    hondaflr Member
    I have a 1995 accord exr with a 94 prelude h22a, im having a problem with check
    engine light coming on either when vehicle warms up, or when at a steady speed and stays on. the problem im having when i want to go check the code, is once i turn the vehicle off, then turn ignition on, check engine disapears, im wondering if computer stores the code, or if it erases, and if i can check it while vehicle is running. hopefully i can get sum answers, there is also a slight stumble when check engine light is on, but barely noticable. what can i do? thanks
  2. cws13
    cws13 Senior Member
    Athens,GA
    Just check it with the car runing.
    Yes they store pending codes, but you will need a scan tool to read these. No blinky blinky
