Quoted post[/post]]
I have a 97 cx with a b16a inside and the check engine light is on I think its because my car is an obdII and my engine is an obdI I would like to know if there is any way that I can make this compatible so that when I get the emissions checked I wont fail
Quoted post[/post]]
Quoted post[/post]]
What ECU do you have. If you used your stock ecu it is probably because of vtec, egr, and few other pieces of randomness. go to a parts store and get your codes read.
