check engine light wil not reset.
Discussion in 'HYBRID -> EG-EK / DC' started by govic, Jan 26, 2009.
  1. govic
    govic New Member
    I recently put a d15b engine and transmission into my 93 honda civic cx? i think, with a p08 ecu. The engine runs fine but the check engine light will not go off, i tried getting and engine code by jumping the wires but it will not give me a code. I also don't know if vtec is engaging. THANK YOU, for any suggestions
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    Disconnect the battery for a few minutes and it should reset the ECU. If it comes back on, then something is tripping it. How are you looking for the codes? Paperclip?
  3. eg6sir
    x2
  4. govic
    govic New Member
    yes, I am using a 2 inch wire to get the codes, but the light will not flash. It just comes on and stays on
  5. govic
    govic New Member
    oh, and i took the ecu fuse out and disconnected the battery cable for a few minutes already
  6. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if the light dont flash when you jump it. im thinking it may be a wiring problem because it should flash
  7. ntenc1
    ntenc1 New Member
    ^^ I think the same thing^^
  8. govic
    govic New Member
    Thank you guys for your help.
