check engine light
Discussion in 'ECU's, Electronics, and Tuning' started by hybrid79, Apr 24, 2009.
  1. hybrid79
    hybrid79 New Member
    Hi we have a 96 accord and the check engine light has stopped comming on when we turn the car on and the car wont start, sometimes it will come on and the car will start, any ideas?:mellow:
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    bad switch
  3. hybrid79
    hybrid79 New Member
    switch which switch?
  4. AHHVTEC
    Alabama
  5. BLOWN-EK
    BLOWN-EK New Member
    San Diego
    change the main relay and check all fuses. main relay should fix it.
  6. hybrid79
    hybrid79 New Member
    We replaced main relay but no go, also noticed battery and oil pressure lights dnt light up any ideas?
  7. AHHVTEC
    Alabama
    :idea:
  8. hybrid79
    hybrid79 New Member
    Yes but abs light and and srs light come on which is switched by ignition?
  9. hybrid79
    hybrid79 New Member
    earth had broken off all solved cheers;)
  10. AHHVTEC
    Alabama
