Check For Lsd
Discussion in 'General Tech and Maintenance' started by breakdancingbob, Mar 17, 2003.
  1. breakdancingbob
    breakdancingbob Member
    I just picked up my b16a and I am supposed to have a lsd in it. how do I check for it before I put my motor in.
  2. breakdancingbob
    more specific please
  3. SixtySecondAssassin
    Austin, TX
    pull off the half shaft if its not already off, and if you can see straight through the differential, no bars going across, its lsd equiped. or you can just rotate the half shaft and see if the other side spins in the same direction.
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    This stamp is one way...
    The other is,if you look through the holes where the axles go in you should see nothing...
  5. enemycivic
    enemycivic Member
    that or just jack the car up and rotate one wheel while in Neutral. If both spin then you have lsd if not then none. I think thats a way you can check??? please let me know.
  6. xj0hnx
    C.C.TX.
    Yes,that's the other way,you can do what 60 sec assassin said with just the axles also,if it isn't mounted.
  7. enemycivic
    enemycivic Member
    I think that checking through the hole is a the best way to tell because the stamp can always be fake? I think I have read somewere were thats easy to do. What would be a way to tell if its the factory lsd and not the aftermarket ones?
  8. xj0hnx
    C.C.TX.
    Aside from the Phantom grip,most of the aftermarket LSD's are better than OEM,and even the Phantom grip gets props.
  9. SixtySecondAssassin
    Austin, TX
    if the wheels or shafts spin in the same dir, you either have an lsd equipped tranny or someone welded the differential. if they spin the opposite direction you dont have a lsd. the best way to tell is to look through. steve argueta at hmotorsonline told me that only the cable tranny with lsds and type r trannys are ever stamped. i dont think it would be a bad assumtion to believe him with the amount of engines he moves.
