Chipped My P28-051 Ecu
nuc79
It's a mugen-spec ROM from eBay. I used Pills_PMD's instructions, and also converted it from AT->MT using the RP17/18 fix. Anyway, it runs great and revs freely at idle, but as soon as I put it in gear and take off, it dies. I've plugged the ECU into a EG B16A car, and a EG D16Z6 car with the same results. As soon as I noticed the driveability problem, I went back and re-checked all of my solder connections. That's when I decoded the resistor colors on the R54 resistor and noticed they had sent me a 10kohm one instead of the 1.1kohm that's in Pill's instructions. Could that be causing it? Because the link they sent me with the chip specified a 10kohm one.
You can use a 10k or a 1.1k resistor. I've done both and they don't make a difference.
Can you rev past 3000 freely? If not, then it's in the coding of the chip, and you need a replacement.
To answer your question, yes, it revs all the way to redline in neutral, but dies upon acceleration when in any gear. Do you think it could still be the Mugen-EPROM chip? I know that the problem is in the ECU somewhere, because I have a stock unchipped P28 ECU that works well in the same car. But it's really odd that this ECU had no problems whatsoever before it was chipped.
And Pills... I know that you referenced your instructions from Hondata, meant no offense to you at all. I'm pretty sure it's my defective components, not the instructions I used.
Besides, I know if it was up to you, all wanna-be-JDM-spec-racing chips would be in the trash, where they belong :D
But that's why I'm still saving for Hondata
