thegreat1310
ok i chipped my po6, how do i know if the engine is running off my new chip and not the stock program?no check engine light is on and runs normal
Quoted post[/post]]
no i dont care bout that cel shit, ill know if theres somthing wrong if the engine does run right,plus i know im running ok,and the stock map sensor can read up 2 17psi or somthing like that im conna get a chip burner and wideband
Quoted post[/post]]
I always thought you needed to replace the MAP sensor with one capable of reading boost when you went turbo, at least if you aren't planning on running one of those stupid hack systems with an fmu and missing link and such. The chip might read boost, but the stock map only can register a certain amount of positive pressure in the manifold before it goes wtf. Toss that ebay chip in the trash and get a custom tune by someone if you are running a turbo. 'you'll blow yourself to pieces' . But seriously, ebay chips are crap.You probably want to keep the cel for it's normal use, rather than use it as a shift light too.
Quoted post[/post]]
hey moron if the tps went bad the car would run like shit doy moron
