chipping out p30
quadrida88
was wondering mainly about the knock sensor for the b16 sirII in 95 coupe ex, and how to go about wiring it. i heard i can just chip out the stock p30 and it will eliminate wiring it and the cel? what are some good sites so i can chip it out?
Just burn a P30 basemap and disable knock sensor and your set.
If your engine has a good knock sensor then just run a single wire from the knock sensor to the ecu and the pinout is D3 and thats it your set. Thats the easiest/cheapest way.
