Choppy D16Z
Discussion in 'General Tech and Maintenance' started by EG6D16Z6_NA, Sep 5, 2003.
  1. EG6D16Z6_NA
    EG6D16Z6_NA Member
    aight, my d16 was bogging out a couple weeks ago, so i thought it might of been something. when you slam on the gas peddle, it slumps and dies out. then i changed the spark plugs, this time if you slam it, it slumps then picks up. then i changed the distributor. it just slumps and picks up. anybody know whats wrong?
  2. E_SolSi
    check the timing
  3. EG6D16Z6_NA
    EG6D16Z6_NA Member
    which cylinder is number 1. the one on driver side, or passenger?
  4. no2psi
    no2psi Senior Member
    driver side is the number 1 cylinder.
