Civic 91 Bad oil leak
Discussion in 'Civic and CRX - EW' started by BenLatour, Aug 13, 2007.
Thread Status:
Not open for further replies.
  1. BenLatour
    BenLatour New Member
    Hi,
    I got a civic 91 DX 1.5l and I juste changed my Oil pan gasket and all my valve cover Gasket too and I still got a very bad oil leak when my engine is running
    Can't figure where the leak is coming from. It look like it is a little up of my Oil filter.
    Do someone have an idea of what it could be.
    Thanks
    Sincerly Tower
  2. freak86
    freak86 New Member
    Southwest Michigan
    not sure where the oil pump is on there, but eh. that's just a guess. might want to try degreasing it to see where the fresh oil comes out. also, get a mirror in there and try to see it better.
  3. joey420ny
    joey420ny New Member
    Oil Leak
    Check The Gasket Behind The Oil Filter Housing
  4. formby
    formby learning in progress
    what color is the oil pan gasket?
    the blue ones suck, you need oem from the dealer. also dont over tighten the oil pan bolts.
    it could be the oil pressure sensor.
  5. joey420ny
    oil leak
    the part number for the oil pan gasket from honda is 11251-p01-004 IT GOES FOR 27.03 AND I HAVE IT IN STOCK AT NARDY HONDA IF YOUR FROM LONG ISLAND
  6. CivicCrush
    CivicCrush New Member
    check the dizzy gasket thats were mine was leaking at the o ring on the dizzy
  7. Srac Etahi
    Srac Etahi New Member
    I have a 91 civic dx, and i'm having the same problem. Oil leaking onto the exhaust and smoking like a bbq pit. I'm guessing from what i've heard on here and seen on other sites its the oil pressure sensor. Anybody know where to get one? I looked on a couple auto parts stores websites and can't find it. Hook a brotha up.
Thread Status:
