damn thnk god i still have the old motor in my garage. so i guess i should pull out the ac and everything with it, and how much do you think the a/c bracket would cost? Wouldn't someone like a good honda and acura junkyard carry that? Install shouldn't be that much neither right? just hook up and add freon? Advice greatly appreciated as california is HELLA hot during summer time.Quoted post[/post]]
I think for the SiR II you can reuse the D series everything if you have the SiR II AC bracket.
I have never seen any condensor bolted to a block. I've seen compressors bolted to blocks. I assume that is what you meant. The answer is yes, with a compressor bracket from a del sol that had a dohc engine or a crv's bracket, it will work.Quoted post[/post]]
If you can bolt the condensor to the block and get a belt the right length, I'm sure you could make the rest of it fit without too many problems.
Can you bolt a D series condensor to a B series block anyone?
I paid about $100 for a new one from a dealer online. They aren't cheap for some reason.Quoted post[/post]]
106 here today, that is why i work nights.Quoted post[/post]]
just like texas I dont put my actual shirt on until i get into the parking garage at work....i look bad with sweat marks on my back.
