Civic clutch cable
Discussion in 'Integra' started by girma, Nov 6, 2007.
  1. girma
    girma New Member
    I've gone through 3 clutch cables in the past few months. Makes me wonder: do I need a different cable than the one I'm using?
    Acura GSR in a Honda Civic Si, 1989
    I'm using the Civic clutch cable that goes with the Si Hatchback. Question: Does the Acura engine make that cable a bit short or something? Along with the cable breaking, the support and hinge under the clutch pedal must be giving because the pedal no longer engages the starter interlock button under the pedal.... Anyone run into this problem before??? Thanks.
