Hello friends !
well im going to do an ITRengine swap into my ek coupe civic 96 (d16y8 engine).
I have got the parts 4 the swap Please tell me if im missing something.
a. del sol AC BRACKETT SWAP SI.
b. Civic Si rear Mount Bracket.
c. CIVIC SI left hand MOTOR MOUNT.
d. INTEGRA 94-02 FRONT ENGINE MOTOR MOUNT BRACKET.
e. AXLEs from INTEGRA 94-01.
f. intermediate shaft +3 bolts.
g. integra,civic,GSR shifter linkage,w/shifter.
h.INTEGRA TYPE R THROTTLE CABLE KIT.
i. Fuel Filter/Line/Rail/Adjustable FPR.
j.Integra Power Steering Pressure Hose.
k.2001 Acura Integra Power Steering Pump.
l. Water Pump integra Type R.
m.Integra GS-R New Timing Belt OEM + Tensioner, Bolt & Spring.
n.Rear Main Seal +Cam Seals + Intermediat/ Axle Shaft Seal + Shift Shaft seal.
o. Upper $ lower Radiator Hose from civic Si
Thanks guys !!
