Civic Dies At A Stop
Discussion in 'General Tech and Maintenance' started by randerson165, Jan 16, 2003.
  1. randerson165
    randerson165 Senior Member
    Eugene, Oregon
    My buddy has a 99 civic with sohc engine. he has aem intake, fuel regulator, dc header, dc exhaust, my question is, when his car comes to a stop, it will sometimes die, if you push the clutch in prior to stopping it will die, but if you downshift and ride it out to a complete stop it will sometimes idle ok and not die. what could be the problem ?
  2. Havok
    Havok Senior Member
    Florida
    Is it just completly dieing, or will the revs drop, lights dim, etc? Sound like it's not getting enough fuel, are the intake and fpr installed correctly? I had my aem short ram fucked up, when I put on my full one I actually followed the directions--my car used to die as well at stop lights, signs, etc.
  3. SolReaver
    SolReaver Senior Member
    check for proper fuel pressure
  4. randerson165
    Eugene, Oregon
    The revs drop and it dies. It is an aem full length intake. It was installed by a shop. What should the fuel pressure be set at ?
  5. sportlinecrx
    sportlinecrx Banned
    have you tried adjusting the idle speed? just in case you haven't.
  6. randerson165
    Eugene, Oregon
    Where can I adjust the idle speed, and what should the fuel pressure be set at, I think it is at 15 right now.
  7. exhacker
    exhacker Member
    TN
    i would try resetting the ECU, too. take the fuse out and disconnect the battery for a time. not sure the exact process, sorry. also, yeah, check the idle speed & fuel pressure. is your butterfly valve well lubed and adjusted? is your intake manifold nasty & dirty? try totally cleaning out the intake manifold & butterfly valve, with the car kinda tilted on a hill so the cleaner goo runs out, instead of in, the intake. then, do a total re-adjustment of your throttle cable. If it's a swap, you may not have the right cable(?).
    can you tell if the clutch is totally disengaging? after my swap, the clutch started having problems. I think if I had let it go any longer, I probably would have had the same symptoms. My clutch was not disengaging properly... to the point where I would be all the way to a stop, and the engine would bog, meanwhile not letting me shift out of gear. Once the engine died, however, I could shift into 1st, and starting the car let me notice a jerk on the drivetrain and a ½" drop in the clutch pedal, as the engine turning over was forcing the clutch to disengage. I'll try to think of what else it might be.....
    -x
