Civic door question
Discussion in 'Body / Exterior / Interior / Cosmetics' started by HatchSpeeD, Aug 7, 2005.
  1. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    On my 94 cx hatch's doors, it doesn't have that big black stripping in the middle of the door going horizontally like the other civics. But the body is filled in there, meaning there is no holes. Other civics(DX, EX) i've seen that HAD that stripping there but its removed, have holes all along where the stripping was. I only ask because I need to change my passenger side door and i'm interested in buying a door from someone online buts its the one with the big black strip along the side of the door where as my driver side door does not have that. So obviously I want to make it look even & take it off but was wondering if anyone knew if the doors are different and will have holes underneath the stripping in which case i'll just look for a cx style door instead, if its different. THANKS!
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    Yep...
    I think only the VX and CX had no moldings.
    The others will have the holes in the door.
  3. phunky.buddha
    Dallas / Fort Worth, TX
  4. 5thGenLuvin
    5thGenLuvin Senior Member
    simply remove the moulding, weld a tiny metal backplate over the holes, fill with bondo, prim and paint, that's how you shave the mouldings in the first place:p
  5. 92civicb18b1
    i don't think he want to "Shave" them. He just needs a new door.
    It's a lot more work and time then you make it seem also.
  6. Boondock Saint DX
    Boondock Saint DX Senior Member
    Des Moines, Iowa
    so id have to weld a metal strip over the holes if i removed my door trim on my dx?
  7. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
  8. 5thGenLuvin
    I was a bodyman for 2 years and I never saw a difficulty to it... it's alot easier then prepping aftermarket plastic bumpers for paint:/
  9. 92civicb18b1
    then you're doing it wrong.
    I personally think the best way to shave them would be to weld tiny little strips to strenghten it. Then bondo. Maybe I'm not understandig what you're saying...
    ______________________________
    kinda like that. Then the bondo won't crack as easy
    With the holes.
    ___________________________________
    | o | o | o | o | o | o | o | o | o | o | o | o |
  10. 5thGenLuvin
    I mean to fill the little dips left where the holes had backing placed over, not to take the entire bodyline out.... and btw, welding little strips in it like that would take forever, and I've never had bondo come out of a shaved handle or moulding yet.
    Maybe you don't do it right:/
