Hi everybody,
i just get a b18a2 engine to do a swap to my ej1 that has a d16y7... you maybe asking "why you buy a too old engine?"... well i get it just for 300 bucks the longblock with stock header and intake manifold... so i think is ok to be a project...
my question here is:
1. What can i do to this engine?
For know i will do a overhaulin', so i will put some high comp pistons, ITR oil and water pump with timing kit gates blue. what do you believe?
2. What tranny i can look?
as i know the best tranny is the ITR tranny that have better final, but here in panama it cost 1600 usd bucks... so i'm looking for a VTi or SI b16a2 or b16a tranny... that has a good gears too... what do you think?
3. What Tranny clutch kit can i buy?
well the engine was automatic, so it comes with the turbine (AT), so i must buy a full clutch kit with flywheel right?, so i'm thinking on buy a XTD complete clutch kit with flywheel 9 lbs... is ok?
4. To Complete the swap, what else i need?
engine mounts?, shift linkage?, what else?
for know this are my questions, hope you can help...
Thanks,
Jesús
Thanks,
Jesús
