Civic SI 99' engine, suspension SWAP toaCIVIC 93'
r.2
i buy a CIVIC SI 99' TOTAly crashed and a civic 93' coupe, i want to swap all the componets like brake and engine...
into a civic 93' NON-VTEC... what i need???, the VTEC wiring??, i can use the same ENGINE MOUNTS??? the SI have ABS, i will have a problem putting the ABS in the civic 93'??,
You can swap the engine and tranny but not the suspension parts. You'll need to wire up a couple of vires for vtec, I think you can use the driverside mount from the SI.
Hey, man, i having a problem with my swap, its a 99 si into a 92 dx hatch, im using a obd1 harness and and the car is not starting?
Please reply back Anyone
hi,
the car turns over, but it doesnt catch, when I had the obd2 distributer in there was no spark, but now with the obd1 distributer there is spark, but the car still will not catch, I heard someone say that the timing might have jump, how do i fix that?
Please help
Thanx for replying
