Civic Swap help....
Discussion in 'Civic and del Sol - EG and EK' started by big4, Mar 4, 2009.
  1. big4
    big4 New Member
    I was searching, but can't find any info on what parts I need to swap a JDM OBD 1 B16a into my 95 Civic EX EJ1. I want it to be simple no cutting wires. I also read on here that a B16a is more work then a B16a2 or B16a3...is that true?
    Motor: Buying a JDM B16a
    Tranny: Buying a JDM B16 tranny non LSD :(
    Wire Harness: Knock sensor? I want to do it right and clean. Should I buy a JDM harness?
    Axles: Integra? What year?
    Shift linkage: Integra? What year?
    Motor mounts? I have Innovative mounts 60A. Do I need integra bracket (Rear)?
    ECU: P30 with an S100.
    This thread says a B16a for 5th Gen is not worth it, hard.
    http://hondaswap.com/swap-articles/engine-swaps-101-a-29052/
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    its the same swap as a b16a obd1 swap the only difference is the wiring so try and search again
  3. big4
    big4 New Member
    I think I need a JDM wire harness or Delsol 94-95 cuz of the knock sensor. Will an OBD I Integra work with no cuts?
    Do I need an integra rear mount bracket? I read that I do...
  4. big4
    big4 New Member
    Can I use a JDM engine harness on a USDM car?
  5. sloefdud
    sloefdud New Member
    nashville,tn
    to save you money dont buy a harness. if you have an eg the harness is exactly the same. all you do is plug and play. you can delete the knock sensor off of your ecu. whoever chipped the ecu you can just have them delete it.
  6. sloefdud
    sloefdud New Member
    nashville,tn
    i swapped my b16 into my 95 ex and it was all the same. if you dont have a ex with the d16 then all you have to do is wire the vtec in
  7. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    if you're car wasnt vtec you would need to wire it in yourself but since it is you can just use your stock harness and ive never heard anything about that being more difficult then the other b16s.
  8. big4
    big4 New Member
    Thanks everyone for your help......
  9. big4
    big4 New Member
    How can you tell the difference between stock JDM B16a cams and CTR Cams? Any markings?
  10. sloefdud
    sloefdud New Member
    nashville,tn
    the ctr cams will have a bigger lobe on the vtec. only way to tell the difference is to put them side by side
  11. big4
    big4 New Member
    The guy I'm buying a motor from said it's got CTR cams....Wish I could tell if he's BS or NOT.
    What axles will fit perfect? Del Sol?
  12. sloefdud
    sloefdud New Member
    nashville,tn
    yeah. what are you putting the motor in
  13. big4
    big4 New Member
    I stated it was a 95 Civic EX.(EJ1)
  14. big4
    big4 New Member
    Would Del Sol axles for a B16 fit better then integra axles?...
  15. big4
    big4 New Member
    I searched an found it..94+ Integra or 94-95 Del SOL (DOHC)
  16. efhondakid
    Akron-Canton, Ohio
    There are markings on the cams that you can tell what they are with out mic'ing them.
  17. lsekcoupe
    lsekcoupe New Member
    haterstown maryland
    as long as the motor is obd 1 u use ur harness and extend two or three plugs u do need the rear t bracket and linkage and the passenger block mount
  18. big4
    big4 New Member
    Thanks...passenger block mount? What is that?
  19. big4
    big4 New Member
    What am I looking for?
