civic swap
Discussion in 'Civic and del Sol - EG and EK' started by importphanatic94vx, Apr 12, 2007.
  1. importphanatic94vx
    importphanatic94vx New Member
    ABERDEEN,WA ORIGINALLY FROM YAKIMA
    i have a 1994 honda civic hb vx..with the vtec-e..i want to put the d16z6 motor in my car..i was just wondering what i have to do to do the swap..i know you have to get a p28 ecu and you can use the original half shafts and tranny..but other then that i need help on my swap..
    thanks devan
    i got a d15z1 in my car now but i want a d16z6..
  2. importphanatic94vx
    help me i need to know how to do the swap please!!!!
  3. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    it's pretty much a drop in, wire it up deal... everything plugs into the same locations (assuming it is the same obd number)
  4. importphanatic94vx
    any other help?
    any one else got any input for me thanks!!
    devan
  5. Eg6nRpS13
    Eg6nRpS13 Junior Member
    you would probably have to do the 7 wire o2 sensor conversion to the 4 wire o2 sensor also, the vx has a 7 wire o2 sensor and the d16 has a 4 wire o2. Im pretty sure you can find the conversion help sheet somewhere on this site
  6. importphanatic94vx
    5 wire
    mine is a 5 wire colors are-
    orange
    yellow
    white
    red
    black
    anyone know how to hook up a 4 wire for a d16z6
  7. Eg6nRpS13
    sorrie about that, I meant a 5 wire to 4 wire conversion, I was thinking 7 wire on somthing else, I will try to find the write up on the conversion and im you the link.
  8. importphanatic94vx
    anything else to help me with the swap?
    i wanted to change the head gasket,oil pan gasket and valve cover gasket before i installed it..but some guy told me not to touch them till i see that they are bad..that ture or jusr change them?
  9. Eg6nRpS13
    I would just replace it if you have the funds, prevenitive maintenance. Do it right the first time so you don't have to go back in and do it again. Its a lot easier to do it while the engine is out.
  10. turbo sol
    i'll second that... just replace them.
  11. importphanatic94vx
    ecu?
    so i can not use my stock vx ecu?
  12. lewellgd
    lewellgd 92CivicHatchCxBORNINCALI
    The motor will just drop in and plug in. d16z6 is only obd1 so no prob there and do not use the vx ecu or u might as well not even do the swap. GET THE P28.
