ok i repalce the drivers side axle right well it has a b18 ls motor out of a 93 integra im guessing because it has the half shafts well i get everything put together and when i tunr hard i still here a grinding can it be the wroung axle it has 5 lug itr swap on it it has size 32 mm axles umm can sumone help me
its a jdm motor so wouldnt it have came with jdm axles , so im amsuming i have to change intermediate shaft to a usd 94 integra and use integra axles Rightt
ok all the axless i tred dont fit the 90-93 integra axle is like 1/4 inch to short, the 94 to 00 has wroung end on it so i was wondering can i change the mid shaft to a diff one and buy a axle that will work like 94 up integra
You have to use integra or civic type r axels from what i hear, Something about the number of teeth. Try googling it.
