ckf question
BigBitchesFTW
New member!!! This site kick arse
Ive got a obd1 b18b1, im converting it for obd2...can i wire up the ckf sensor if i put on a obd2 oil pump..what does it consist of doing
save your self the trouble and just jump it to the cam sensor, your going to need the crank sensor and the bracket. and im not even sure if the engine block you have has the mount holes for it to bolt up unless there in the oil pump-(I never realy checked) ... i've done a few swaps and i havent used the crank sensor yet . but i did have a timing belt break on my wifes car and rip the whole ckf set up right off. all my setups ran fine with the ckf bypassed ( no CEL)
