its throwing this code after installing a 99 b18c1 swap into a 98 dx hatch. my question is, where is this sensor located? would it be the same as the crank angle sensor? any help is greatly appreciated. thanks, Sal
yeah its the crank sensor. what ECU are you running? if you're running an OBD2, then you have to plug this sensor. depending on the harness you used, find the plug that will plug into the Crank Sensor (located by the oil pump, drivers side, by a/c. if you're using a 96-98 harness, then the plug on your harness is a 2 pin plug... you need to get the 3 pin plug from a 99-00 sensor, change the plugs (just match up the wires with the same color, and dont worry about the 3rd missing wire, its just a ground. if you need anymore help let me know at edwardrodriguezjr@hotmail.com
