$700 bucks from my boss.... Key Features: * ProAudio Unit * Fully Motorized, 7" Wide-Screen Color LCD Monitor * Touch-Panel Control * Single Play DVD Mechanism Plays DVD Video, * Plays MP3-Encoded CD-R/RW Discs * Radio Tuner With 18FM / 6AM Presets * Sirius Satellite Radio Ready * CeNET Control of Optional Dolby Digital / dts 5.1 Processor, TV Tuner, Sirius Satellite Radio Receiver, DVD Changer and 6-Disc Audio CD Changer * Multi-Changer Control, CD Text, CD Titling (Audio Changer Only), Station Titling * 3-Band Parametric EQ (Beat EQ) * 2 A/V Inputs (1 RCA, 1 CCA389) * Rear Vision Camera Input * 4-Volt, 6-Channel RCA Line Level Output * 24-Bit DACs * Fiber Optic Output for Use With DVH940 5.1 Dolby Digital / dts Decoder / Processor * Excellent Off-Axis Viewing * 336,950-Pixel Display * Screen Resolution of 1440 x 234 * 212-Watt (53W x 4) * IR Remote Control * Partially Detachable Faceplate * 4-Channel Loop Back Circuit Detailed Specifications: FM Tuner Specifications: Frequency Range: 87.9MHz-107.9MHz Useable Sensitivity: 9 dBf 50dB Quieting: 15dBf Alternate Channel Selectivity: 70dBf Stereo Separation: 35dB Frequency Response: 30Hz-15kHz DVD/CD Player: Frequency Response: 4Hz-44kHz (96kHz) Signal to Noise Ratio: 100dB Dynamic range: 100dB Distortion: 0.02% Audio Amplifier: Rated Power Output: 18W x 4 (20Hz-20kHz, 1%THD, 4 ohms Maximum Power Output: 212W (53W x 4) Speaker Impedance: 4 ohms Input/Output Specifications: Audio Input: 130+/- 60V rms Video In/Output: 1.0 +/- 0.2Vpp (75 ohm) LCD Screen Specifications: Screen Size: 7 inches (wide screen) Pixels: 336,950 Resolution: 1440 x 234 General: Power Requirement: 14.4V DC Current Consumption: 4.0A Weight: 4.1 lbs Dimensions Main Unit: 7" x 115/16" x 6 1/2" Dimensions Tuner Box: 7" x 1 1/2" x 8 1/4
what do you guy think i could do in order to exange the unit between 2 cars the set up is made up of two parts DVD/CD Player: and Audio Amplifier: the harness its self hooks up to the hidden unit so i have to extend the wires, so i think ill make two sets of male/female wire extentions and make a 2-1 harnes on both cars... possible? what would you do? is this tv tunner worth it? Key Features: UHF/VHF TV tuner for local (non-cable) broadcasts. The tuner receives stereo TV signals (channels 2 through 69) four-antenna Diversity Tuning System You may use the TTX7501z with CeNet-equipped Clarion in-dash receivers controls. The tuner has one A/V input (requires an optional CCA389 cable), allowing direct connection of a VCP, DVD, or video game without the use of an outboard A/V switching unit. $199. on egay
nice unit. you'll only be able to keep the unit in one car not two. tv tuner is nice add on, if you want to watch tv in the car should come with the headunit and what they call a brain (which has all your rca connections) and yes you'll have to extend the wires from the brain to the headunit $700 not a bad price either
thanks i got this guy to instal a viper 350, 3 auto door locks for my hatch and the head unit for$ 450 including the price of alarm. is that good?
well it costs $249 @ best buy installed but the auto lock set up is $80 a door x3....and $149 for the radio install but its been two weeks and the guy stood me up again... last week he said he was sick, today ?????
alarm install price not bad, 80 per door on autolocks isnt to bad (pain to get right if you dont know what your doing), 150 for the radio is kinda high to install (my dvd player took me 20 minutes to install)
