Clearing Out Headlights
Discussion in 'General Tech and Maintenance' started by 93Fury, Jun 27, 2003.
  1. 93Fury
    93Fury Member
    Ft. Lauderdale, FL
    Hey, this is my first post, and im hoping its in the right place. Sorry if its not. Im working on a '02 civic coupe, and were trying to remove the amber from the factory headlamps. Does anyone have experience with doing this or know of a refrence on the net? I hope so, I dont want aftermarkets I want the stock ones clear. Thanks alot guys.
    Ryan
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    on the Del sols you can check out Teamdelsol.com for info. the only problem on the sols is, the glass is not 100% clear, When you have a white light shinnying through, there is a nasty brown tenge.
  3. SkorchedZero
    SkorchedZero Member
    The K-hole, NC
  4. 93Fury
    93Fury Member
    Ft. Lauderdale, FL
    Thats alot guys! I searched for 3 days and couldnt find anything on the topic! That write-up was great, and the pics help a million. :thumbsup:
  5. SkorchedZero
    SkorchedZero Member
    The K-hole, NC
    I did it about a week ago and drove in the rain once and washed the car once and no leaks so far. Thanks wrote it myself! haha
  6. ef9civicgen4
    ef9civicgen4 Senior Member
    Independence MO
    if you don't want to take the assembly appart. do what my friend did. take the signal bulb out, the use needle nose pliers to take the reflector off the inner part of the assembly, grab the reflector with the pliers(grap tight) then break the reflector(crush it, twist it, im not sure how he didi it, just break it) :D into pieces small enough to fit out of the socket.
    then you don't have to wait for the silicon to dry and you don't have to worry about leaks.
    oh yeah, i would take the assenbly off, it makes things easier.
  7. SkorchedZero
    SkorchedZero Member
    The K-hole, NC
    You might risk scratching the lens. Be careful if you do it that way.
  8. nimblecivic
    nimblecivic Senior Member
    Southern IL, across the river from the Stl...
    even though ya already got it done, here's a good link....
    clear lenses
    My finance' has an 02' and I'm using these instructions on hers when I get off my ass........ :D
  9. h82w8
    h82w8 Senior Member
    orlando,florida
    is that supposed to be finance' or do you mean fiance' ;)
  10. nimblecivic
    :lol: I meant fiance'.....lol...my bad...
    but now that I think about it, finance' is a better term.....
    she ownz me AND I get the benefit of her taking all my cash..... :lol:
