clicking noise..
Discussion in 'General Tech and Maintenance' started by eg6sir, Jun 15, 2006.
  1. eg6sir
    ok.. i had previously had a squealing (<-probably spelled wrong) noise coming from my brakes.. well.. i was listening carefully and it makes 2 or 3 clicks from the driver side when i first start moving.. is this a wheel bearing or something.. :shrug:
  2. get_nick
    Washington State
    it might be an axle popping.
  3. eg6sir
    well.. i will be changing my brakes this weekend.. i'll check everything out.. if anyone has any more ideas of what it could be.. let me know
  4. eg6sir
  5. BlueCrxNC
    BlueCrxNC VTEC CRX
    If it's a wheel bearing then lift the car and let the wheel in question hang free. Attempt to pivot the wheel in and out from top to bottom and then side to side. (push and pull the wheel) If there is a little play then it's wheel bearings. Cost is $50+ each. I had 1/3" in movement on both my front wheels! before I realized it and replaced them.
    Axles will normally give off a popping/clunking sound while accelerating and/or decelerating in the middle of a hard turn.
  6. eg6sir
    yea.. i have no clicking when turning.. only when i first start to reverse.. it only clicks a couple of quick clicks.. hopefully it'll stop when i change my brakes..
  7. brian11to1
    brian11to1 Senior Member
    Sway bar bushings. I just replaced mine and my clicky sound went away!
  8. eg6sir
    when i get in there tomorrow i'll check everything out.. thanks for the help guys.. keep the ideas coming until i get this fixed..
