How can change the light bolt inside the clock of a 2001 Accord Coupe so I can see the digital clock at night? Thanks
well by the looks of your car . you need to pop out the plastic trim surrounding the controls. look for a bulb around the clock area . you might need to remove the clock, usallythere held in with 2 phillips head screws. you should find the bulb by that point . if not then your going to need to replace the clock . if you find the bulb , they pull out and new ones push right in. becareful prying on your facial trim. try to not use any tools to get it off. and when putting it back in . be very careful .
