clocking the center housing...
Discussion in 'Forced Induction' started by 92civicb18b1, May 14, 2005.
  1. 92civicb18b1
    92civicb18b1 The Trisexual
    Rebuilt my t3 42/48. But I never was able to rotate the center housing. Is there a way to break it loose? Every bolt except the two bitch bolts are out and the bitch bolts are loosened. I sprayed some wd40 but didn't go overboard. I was wacking the hell out of it, but I don't want to wack it too hard and throw it out of balance.
    So any ideas. I need to figure this out so I don't blow the seals....again.
  2. pissedoffsol
    you should just be able to loosen the 6 or 8 that go around both the compressor and the turbine, and then clock it freely.
  3. 92civicb18b1
    it doesn't..I gave up
    I just bought another turbo.
    Actually I bought a couple. I bought a t3/t4 and a 42/48. The t3/t4 has a weird DP flange and I have to see if I make it work.
