clunking noise
Discussion in 'General Tech and Maintenance' started by eg6sir, Sep 18, 2007.
  1. eg6sir
    alright.. me and a buddy changed his suspension today and its got a clunking noise in front when he hits any big/medium bumps.. its a 95 Civic EX and we put KYB GR-2s w/ my old Tenzo springs (1-1.3" drop).. we tightened everything up and it all feels secure... any thoughts of what this could be..
  2. humblegumbo
    humblegumbo 1595cc's of Mad Fury
    CA
    Could it be the upper control arm 'bottoming out'?
    Actually hitting the top of the inner fender wall?
  3. eg6sir
    not sure, we're gonna pull it back apart this weekend..
  4. TurboMirage
  5. eg6sir
    we put bump stops in there..
  6. TurboMirage
  7. eg6sir
    nope.. i do remember when he assembled the spring/shock he took out the metal sleeve thats on rubber part of the top hat and put a shorter one in there.. we're both thinking thats what it is because everything else should be correct..
  8. TurboMirage
  9. eg6sir
    gonna take it to his dads shop this weekend and put it on the rack.. its an east coast car so bolts through the lcas are frozen in there.. we hit it with 3 different impact wrenches and nothing.. he's buying new hardware from Honda today and using the lcas i just took off my car, that way we can just drop the whole thing.. strut attached to the lca still
  10. humblegumbo
    CA
    Assuming you already tried the WD40 & BFW (big f*%kin' wrench) combo on those bolts...
    My experience w/ hardware from the dealership is that in the time it takes for them to get what I want I can get the old stuff to work w/ a little love.
    Then again, I have the pleasure of owning a CA car...
  11. eg6sir
    so do i.. he sprayed wd40 on them a couple a days before doing this.. .. nothing.. we tried a 4ft breaker bar and nothing.. i gave him my rear lcas i just took off so we're not worried about it anymore.. and he ordered new hardware from Honda.. damn those bolts are $10 a piece
  12. humblegumbo
    CA
    How lame am I that all I hear in my head is Mr. Dundee 'That's not a wrench...'
    Anyway, 4ft should do the trick...but then again, until you shear the bolts you aren't really trying are you?
    I know. That's why ordering stuff from Honda is my absolute last resort. If there's a junkyard w/in an hour of you, it'd be cheaper to hit them up. Hell, pocket'em and they're free....
  13. blackice90HB
    blackice90HB Senior Member
    Pensacola, Florida
    4 ft=teh weaksauce. get yourself a big ass cheater pipe, the bigger the better. Hell I used a 45lb weight bar to bust the LCA's loose on my Volvo 740, and still took somw work
    its never enough untill you get it to bust
  14. humblegumbo
    CA
    J/K:p
    So, was this issue ever resolved Mr. eg6sir?
  15. eg6sir
    he still hasnt gotten around to taking it back apart.. its just parked for now and he's driving his truck
  16. phunky.buddha
    Dallas / Fort Worth, TX
    Make sure the hardware stack on the top hats is correct- if they're not in the right order, everything will be loose and you'll go clunk.
  17. eg6sir
    thats what we were thinking.. he just hasnt had time to get it in the air again with school and work in the way
  18. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Damn, beat me to it as usual. :p
    I did the springs and shocks on my friend's accord and the same thing happened. The order of the hardware is the culprit I'd assume.
  19. phunky.buddha
