So I searched the forum and could not find a post about cluster trouble shooting so im starting a new thread...
I have a 89 CRX DX, I have swapped a 91 Si engine wiring harness, dash harness, and the harness that runs down the drivers side the the fuel pump, its pretty much an SI...
my question is I have tested the dash harness and its getting power to light up the cluster, I have also tested the wire that goes hot when you turn the lights on to light up the luster, both work fine, I have replaced all the bulbs in the cluster and even tried 3 different clusters, and none will light up, I have even tested the board on the back that the power travels trhough and thats getting power, any ideas?
Check the car out in my gallery
