cluster swap
Discussion in 'HYBRID -> ED-EF / DA' started by crx8787, Jan 2, 2009.
  1. crx8787
    crx8787 New Member
    cluster swap HELP
    Would the 90 to 91 civic WAGON cluster fit in a 90 civic hatch std??
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Got a pic?
  3. 95b16coupe
    95b16coupe New Member
    ct
    why would you want to?
  4. crx8787
    crx8787 New Member
    cant find a pic, but pretty sure the shape is the same, i want to cause the cluster i got has no tach and i dont want to mess up my dash putting a autometer bull**** on. just want to know if plugs are the same
  5. 95b16coupe
    ct
    you should just find another std one. shouldn't be too hard. the plugs would swap straight over.
  6. crx8787
    crx8787 New Member
    but doesn't all the std and dx clusters come without a tach??
  7. K2e2vin
    Raleigh, NC
    CRX DX's have tachometers, not sure about the HFs.
    I actually have a DX one but it's at my cousin's house(about 80mi away)
    Also, if you wanted to, you could put just about any cluster in your car.
    Here's mine(94 GSR): http://i27.photobucket.com/albums/c164/K2e2vin/100_2460.jpg
    The Accord ones seem like it would work better though; too bad I threw mine away.
  8. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    sorry for the threadjack, but how did you do that?
    my 90 came with the GSR cluster but my speedo never worked.
    and I am sure the OP can use an Si cluster and the tach will work, so the wagon one should, I would just try it.
  9. K2e2vin
    Raleigh, NC
    Pretty much just retrofit/wire in the GSR plugs(I actually used a set from an LS since the cluster didn't come with them). You have to swap over a electronic VSS and wire it in. The 88-91's have it built into the cluster.
  10. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    use an SI cluster.done.
  11. kricket3000
    kricket3000 New Member
  12. D16SiHatch
    D16SiHatch New Member
    I believe the wagovan cluster will work just fine.
    and like kevin said you can use a different newer cluster as well. just make sure you wire up the electronic vehicle speed sensor. common ones would be the integra ls/gsr/type r cluster, crv cluster, and the 99-00 Civic Si cluster. i have a 94 ls in mine.
  13. crx8787
    crx8787 New Member
    got a pic of my cluster, what is that box with the blue plug??
  14. mesa50w
    mesa50w New Member
    mine looks like that as well everything but the gas gauge and speedo work in mine but I dont know what plugs into the blue. BTW i"m gettn a 17 code VSS so how do I wire it in as stated above.
  15. Da1andonlyJinx
    Da1andonlyJinx New Member
    Florida
    that blue plug is for cruise control i believe. And the question about the 90-91 wagon cluster, yes it will work. I have a 90 wagon and have switched between the hatch and 4 door clusters in my wagon.
