Clutch Adjustment ????????
ryangt
i just got done putting a new clutch and throwout bearing and all that jazz in my 90 hf rex, i need to adjust the cable but the info in the tech articles a little sketchy, The stock clutch settign was adjusted so it engaged when the pedal was kind of high, i prefer it to engage a bit lower, i know its posssibel cuz my 91 rex with the ls engages just off the floor but i didnt do that swap so im not too sure about it.
any help would be very helpful
thanks in advance
There is a bracket coming off the tranny where the cable comes through, there is a nut there, you just have to adjust that nut and drive it around until you figure out where you like it the best.
