clutch bolt ??s
Discussion in 'Engine Building' started by sevenhillsbilly, Dec 19, 2008.
  1. sevenhillsbilly
    sevenhillsbilly New Member
    i have a question about the bolts on that holdon teh pressure plate. do i have to use the 12pt ones that are there or can i just go get some grade 8 bolts and use them ?
  2. sevenhillsbilly
    bump anyone
  3. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    no they are low profile specially suited to hold your flywheel man. just get yourself a single 12pt socket from autozone or something
  4. sevenhillsbilly
    i got em off but a few of em are stripped and i wnt be able to torque em down so i was goin to get some grade 8 bolts or hardened bolts for it
  5. sufikation
    sufikation Active Member
    Fruitland, ID
    i would think if its the same size/thread pattern go for it. make sure you check your manual and see if this is a good idea or not.
  6. YBLEGAL
    NW Indiana
    i got a set of arp bolts. was cheap, works.
