wannaberacer
Member
hey everyone,
I have a 90 crx with a b18 swap and an s1 tranny. I bought the clutch cable for an 90-93 integra and it doesn't fit right. The adjuster is maxed out and I even had to pull the lever arm on the tranny with a prybar to slip on the cable end... I don't think this is how its suppose to be as the cable is still under a little tension.
I'm wondering if maybe the clutch/flywheel combo is having something to do with this, but I'm not sure. I'm sure I put on the throwout bearing on correctly along with the clutch... has anyone else had this problem!??
