INJEN78
HS LEGEND
Ok try n make this clear n simple.
-91 Civic Hatch
-GSR Hydro Tranny
-Hasport Cable/Hydro Conversions
-ACT 6 Puck
-ACT Pressure Plate
Now when the car is off the tranny shifts fine. When the car is on it wont go into gear. Sometimes it will if you jam it. Then well moving if you push the pedal all the way to the floor it wont dis engage the clutch all the way. So normally your car would go to idle, but mine wont. The rpms stay at the speed im at. If i push the shifter itowards gear with no clutch, but it wont pop into gear the car will try n go slowly but not enough to get anywhere. When at a stop with the car in gear and clutch in the car wont stop, it keeps going. What could this be. Pressure Plate? I already adjusted the clutch cable all the way and no affect. Please lmk asap.
-91 Civic Hatch
-GSR Hydro Tranny
-ACT 6 Puck
-ACT Pressure Plate
