Clutch Cable
Discussion in 'HYBRID -> ED-EF / DA' started by capricefrk013, May 14, 2008.
  1. capricefrk013
    capricefrk013 is waiting for summer
    NE OHIO
    Is the clutch cable longer on the Integra trannys vs the Civic trannys? My civic is a 91 and the motor & trans is a 92 B18A1. My dad fabbed up a new clutch cable mount to make it fit after we put in a new clutch. Basicly he made it lower and straighter. Before that mount, the cable was adjusted till it wouldnt go anymore. It was pulling the clutch up about half way one it was mounted. With the new mount, there is enough room for adjustment for clutch wear over time.
  2. efhondakid
    Akron-Canton, Ohio
    Yeah the Integra cable is longer. I did the same thing on mine. I would rather build something to than spend money you know?
  3. capricefrk013
    NE OHIO
    Exactly what we said. The only draw back to it right noe is that the cable is rubbing its way into the battery. I plan on putting the battery in the hatch anyways.
