clutch cable
EFDX
my 1991 integra cable appears to be just a tad too short as i have the adjuster nut backed all the way off and its not releasing the arm into free play, the tranny is an unidentifiable '92 or '93 tranny (found that much out the expensive way, goddam splines!!).
i have cross referenced honda part numbers and they all show the same part number for '91,'92,'93 rs and ls models. the gs-r had a different part number... DOES ANYONE KNOW IF THE GS-R CABLE IS LONGER THAN THE RS, LS, GS
whats the code on your transmission???should be next to where your block stamp is at???
