clutch change
Discussion in 'General Tech and Maintenance' started by vpower, Dec 9, 2009.
  1. vpower
    vpower New Member
    L.A.
    would like to know what clutch i would purchase since mine went out...i have a jdm b18c with a cable tranny...so, my question is what year GSR would i order my clutch for...thanx
  2. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
    go by the engine your b18
  3. chingo
    chingo New Member
    can you use a 1996 civic ex clutch on a 1991 civic dx transmission?
  4. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    No, do NOT go by the engine. The GSR trannies came with a higher spline count on the input shaft than the 90-91 cable trannies. If you order the clutch for a GSR, the clutch disc isn't going to fit onto the input shaft.
    If you have a 92+ tranny, then yes, the GSR clutch kit will work. But if you have a 89-91 B Series cable tranny, you need to get the clutch kit for a 90-91 integra.
    Start your own thread
