Clutch Fitment Question
Discussion in 'General Tech and Maintenance' started by xj0hnx, Feb 2, 2003.
  1. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Will a LS clutch,flywheel and pressure plate,fit in a B16A siRII (no lsd) tranny,I found a good deal on it and need to know before I order it.
    Ok,first I don't have my car here with me I am in Kosovo,and I don't know the exact tranny code,but as I said above it is a B16A(2) siR II.My wife is going to get the code tomorrow,so I will bump this then,but if anyone has a answer tonight then cool.
  2. iceman
    iceman Junior Member
    From my experience only the 90-91 integra clutch will fit , although i'm not 100% sure , on the 92 and up integra's the input shaft is larger than the early model's.
  3. xj0hnx
    C.C.TX.
    bump,it is a Y21<----my tranny.
  4. xj0hnx
    C.C.TX.
    ttt
    Is the iceman correct?can I tell them I can't use it so they can find some lucky person who can? :unsure:
  5. xj0hnx
    C.C.TX.
  6. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    doesnt fit know from experiance
  7. xj0hnx
    C.C.TX.
    The person I'm thinking about buying it from,asked their mechanic and he told her it will fit any hydraulic B series tranny,so you saying it won't,hmmmm...anyone else? :huh:
  8. SixtySecondAssassin
    Austin, TX
    i thought all b series parts were interchangable
  9. xj0hnx
    C.C.TX.
    Me too but there is the output shaft issue that was brought up earlier,but I figured that since it was a cable clutch in the early teg tranny's that was the issue.The LS that it is from was a hydraulic,this is what I am looking at:
    ACT extreme pressure plate
    ACT steet/strip disc
    Zex lightweight flywheel
    used only 2 months on second car, rarely driven
    Great price too,I'd hate to miss it from lack of knowledge.
