clutch in automatic trans
Discussion in 'General Tech and Maintenance' started by hondakpariaug, Jul 29, 2005.
  1. hondakpariaug
    hondakpariaug Junior Member
    i have an automatic trans. the clutches are bad so is it going to be alot of work to change it. should i change the trans or just the clutches
  2. Guy
    Guy Senior Member
    Yuba County
  3. jdmeg6
    jdmeg6 Senior Member
    So Cal
    :bo: I needed that laugh
  4. hondakpariaug
    ok so i know i dont know what the hell im saying
    but what should i do if when i step on the gas the engune has to go up to about 3000 rpm to start moving
  5. 92civicb18b1
    92civicb18b1 The Trisexual
  6. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Take it to a shop. Honestly, you'd be better off letting someone else, who's worked on automatic transmissions (or even cars) before, do all the work.
  7. 92civicb18b1
    honestly, I wouldn't fuck with an auto trans either. If any of my cars had an auto I would bring it somewhere if there was a problem....but then again, I've only owned 1 auto in my life.
  8. E_SolSi
    car probly has high milage
    trans fluid wat probly never changed
    fluid probly looks like shit
    but here comes the kicker.....
    if the fluid is that fucked up for that long, replacing it with fresh new fluid will probly fuck the tranny all up.... basicly your tranny is shot and right now the sludge is the only thing holding it together
  9. civicious
    Houston, TX
    Your transmission is a lifelong Meth addict.
  10. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    :werd: get it flushed and get some new fluid in there.
  11. brian11to1
    brian11to1 Senior Member
    dont take it apart. dont touch it. take it somewhere.
