Hi, I have a zc motor (out of car), and I am trying to put a `88 crx si transmission onto it. I have a clutch, flywheel, pressure plate, and throwout bearing also for an `88 si. I put everything together & it lined up ok. I put the axels on to test it out, pull up on the clutch lever and the axels move when I turn the crank. There is almost no resistance on the lever too? What could I be doing wrong? Thanks.
