I have a civic with a B18c engine and trans swap. The trans is VERY hard to get in gear with the engine running, with it off it slips into each gear without a problem or without using the clutch. I put the car in neutral, clutch depressed and start rocking it, I then have the trans shifted to 1st. It will not go directly in until the two rotate/align properly, then it gets hard to rock like the car is in gear and the clutch is released and your working against the engine compression. It acts to me like the clutch is not disengaging, I have checked the hydraulic system. No leaks and ops checks fine. Any ideas?? The clutch is an ACT stage 2 installed 5/03. Worst news is this is my first import car and I have only had it 5days. Yes, I did have it checked out by my local import turner shop.
