I was having some problems with the clutch a few weeks ago, i checked the clutch fluid and it was low and dark so i bled the clutch and it was working good until yesterday. I was driving downtown having no problems then all of the sudden my clutch pedel started feeling weird. The pressure is still there and the fluid is still full but when i push the pedal in it won't fully disengage the clutch. So even with the pedal all the way down i have to take it out of gear if i stop to keep it from trying to stall. I can hear the plates rubbing together even when i have the pedal doen all the way. Also it seems that when the engine is really cold the clutch disengages fine but after the motor warms for a couple minutes it stops working. Does this sound like the clutch has just gone out?
Ben
Ben
