CLUTCH PROBS!!! big ones
Discussion in 'HYBRID -> ED-EF / DA' started by sevenhillsbilly, Dec 30, 2008.
  1. sevenhillsbilly
    sevenhillsbilly New Member
    i just recently put my motor back in my car and i put a new clutch kit on it and everything i mated a a6 block to an l3 hf trans i used an xtd clutch. The issue im having is there is no tension what so ever on my pedal the bearing moves freely when i push the lever on the side of the trans but when i hit the pedal nothing happens. i was wondering what could be wrong. i put everything in the way it was when i took it out. need help asap
  2. mikey bottles
    mikey bottles Prof. Bottles
    S. Jersey
    the throw out bearing should only move freely until it contacts the clutch, do you have the clutch cable adjusted correctly? ive also heard of this issue with people putting the throw out bearing in backwards by accident?
  3. sevenhillsbilly
    thats woudl royaly piss me off if i did that i mean i put it in the same way that i had the old one so i dnt see what the prob wud be. but i will adjust my cable to even see if i can get some movement in my pedal back.
  4. D16SiHatch
    D16SiHatch New Member
    did you reattach the throwout bearing springs?
  5. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    no tension on your clutch pedal? you shouldnt be able to move the release arm on the trans very much by hand...the throwout bearing moves very little before pressing on the pressure plate. if you can move the arm all the way up and down theen the throwout is in wrong
  6. sevenhillsbilly
    i figured it out i pulled the tranny off and i forgot the bolt that keeps the shaft lined up i completely forgot it
    what boner move
  7. HATCHET_HONDA
    hobart, indiana
    NICE ONE....:thumbsup:
