What clutch should I use when I do my b16 swap. I hope to eventually run a homemade turbo setup on it with arround 250-300 hp. I was thinking ACT Organic street disk and heavy duty preasure plate, but let me know what you guys think! *btw - this is going to be a daily driven, street car, so I want something somewhat easy to drive -Kai
if your going turbo soon an exedy stage 1 or 2 will be fine. You wont need anything higher than that. I love my oem exedy clutch, don't think it'll last once the turbo is in there though.
I used an Exedy Full Face Racing Clutch with Organic Disk in my B16 SiR swap and I love it. Smooth engagement, good lock up.. Remeber to resurface your flywheel with what ever clutch you use. EXEDY 08-804 was the part number I used for my 25mm spline trans. This fits the 90 JDM SiR Y1 LSD transmission. Pappy
