clutch releases b16a
paulrusso
i can not find i clutch release bearing for my honda the swap is a from a 94 del sol (b16a) i now the the center of all the bearings ive order are to small to fit
throwout bearing?
the bearing that sits on the arm and presses against the pressure plate?
Should be able to just ask for the one for the Del Sol Vtec model, maybe one from a 2000si, or a GSR would work but I'm not sure.
yes order one for integra as they all have hydro Bseries trans and that will avoid the confusion of you geting a D series bearing
