Clutch removal Question
If you are asking if you need to use the alignment tool that was included with your new clutch to remove your old clutch the answer would be no.
The alignment tool is only for installing the new disc and plate.....lining it up with the pilot bearing. Just unbolt the other plate and toss the disc and far as you can...
