Clutch system leak
Discussion in 'Other Vehicle Discussions' started by Dman1100, Jan 10, 2005.
  1. Dman1100
    Dman1100 Senior Member
    Des Moines IA
    i was driving my 240 in some semi-deep snow the other day and the clutch was feeling looser than usual. i checked it when i got back home and the resevoir was empty. it shifted a lot harder and didn't want to go into gear easily. i've been driving my civic since then. today i went to see if it would move so that i could take a look and find the leak. the clutch pedal just hits the floor and stays there. i was able to lift up the front end and look at the slave cylinder and it was the only part that i could find any moisure on and it is definately clutch fluid. i take the slave off and take it apart and the inner bore looks fine and the piston seals don't seem to be cracked at all. should i just swap the slave out or does anyone have an different idea?
    and what type of fluid do you use for the clutch? DOT 3 brake fluid?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    yep normal dot 3/4 will work fine. I would say just replace it. Then once you do that, make sure you bleed the system. Have a freind pump the clutch when you add fluid and have the bleeder valve open (on most cars, its a one way valve so you don't have to reopen and close it to bleed. Just open it, stick a tube on it and catch the excess fluid with a bottle. Once your done, close it back up, pump the pedal again, and you should have full pedal
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    should have refilled the system and pumped the clutch and have someone look for the actual cause of the leak...
  4. Guy
    Guy Senior Member
    Yuba County
    Im not sure it this is applicable on 240s, but a common place in older miatas for hydraulic fluid to leak is from the clutch's slave cylinder. Check there and the master cylinder to see if the seals are still good.
  5. 92civicb18b1
    92civicb18b1 The Trisexual
    I had the same problem with my 944. One day I went out got in to start my shit up, pressed the pedal and it went to the floor, no pressure no return just dropped.
    I ordered a master and slave, got it took me about an hour to put em both in and the pedal felt great after that.
    Anyway if you do replace the slave get the master too, if one goes out it's a sign of the other going to go out soon also.
  6. PhyRe
    PhyRe Senior Member
    ct
    im dealing with this prob in my gsr civic. and it only happend when ive been "playin" with my clutch like dubble clutching playing in the snow trying to shift with out the cluutch. shit other than that its all good. refilled it 2 times bled 2 times. then fine for like a month and then i cant get into 1st. in my case it may be as simple as the top not sitting right. we didnt find any leaks just some brake fluid on the car near the cap but who knows
  7. 92civicb18b1
    why would you do that?
    It could be the whole resevoir leaking or cracked or something.
  8. reckedracing
    NY
    so what exactly is dubble clutching, lol? i can;t wait to hear this
  9. Dman1100
    Des Moines IA
    The bleeder screws are one way? i didn't realize. thanks a bunch for all of the help guys.
