Clutch?
Discussion in 'General Tech and Maintenance' started by WhatsAClutch?, Mar 6, 2007.
  1. WhatsAClutch?
    WhatsAClutch? mdstreetscene.com
    Maryland
    Yeah so this has been going on for a while now but when i get rolling from a stop, you know when you first start moving, sometimes if i let the clutch out real slow the car will hop. almost like wheel hop but REALLY severe. What do u think that could be?
    Also sometimes 5th gear grinds when i shift fast.
    also something else... the tranny code for an 1999 civic ex is s80 right?
  2. ep3moschini
    ep3moschini I R T3H NO00Bz!
    Northbridge Ma
    how many miles on the clutch, how much horsepower do you make and how do you drive? if your rpms are to low you might be bogging it out, and if there high and the clutch is worn it could be clutch chatter
  3. WhatsAClutch?
    Maryland
    haha im not bogging it down, its hard to explain, i do run it toooo hard, there's like 2000 miles on the clutch. when i got the clutch replaced early in the summer of last year they remanufactured the flywheel and i dont think they did to good of a job on the clutch. like at first it would grind into third the day i got it back from the shop but eventually they fixed it.
    im looking at like an exedy stage 2. what do you think.
    oh yeah and when it does this the rpm's are high not low. also forgot to mention that it has slipped outof 2nd twice and third once in the last couple of weeks.
  4. ep3moschini
    Northbridge Ma
    how much power dose your car make? its probably going to be overkill with a stage 2. . . huh, that weird how it happens at higher rpm's. could be clutch chatter. . . or the friction meterial is comming off (serriously doubt that)
  5. WhatsAClutch?
    Maryland
    oh its a d16y8 with intake and exhaust. so prolly like 135? i guess thats a good estimate. you think that would be overkill with a stage 2? i want something that will last considering i run the fuck out of it.
    i cant afford a swap so im stuck with that
  6. ep3moschini
    Northbridge Ma
    your motor is probably making more like 110 to the crank and you can use a stock clutch, im almost 100% shure you dont need a stage 2 yet lol, learn how to drive with out beating the shit out of your car and it will last because your making no more than 10hp over stock if that to the crank
  7. WhatsAClutch?
    Maryland
    yeah so first off i know how to drive it, i beat the shit out of it because when it blows up, the i have an excuse to swap a new engine in. and 110 to the crank how so? theyr'e 127 stock.
  8. ep3moschini
    Northbridge Ma
    you think your making an extra 30 hp from an intake and exhaust thats just rediculous
  9. WhatsAClutch?
    Maryland
    last time i checked 127 + 30 Does not equal 135, u dont have to be a math major to know that one, come on are u serious or can u just not read.
    i said they make 127 stock plus intake and exhaust, should be around 135 now maybe a little less.
    Still that has nothing to do with the topic, i want to know why you think a stage 2 would be overkill.
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    Being that your clutch is so new, its a possibility that you didnt break it in properly. (There is a procedure for that). If you didnt break it in correctly its possible that you've either glazed the clutch surface, or the flywheel surface. Or even overheated the flywheel and warped it. All of which would cause that chatter.
  11. ep3moschini
    Northbridge Ma
    just to clear up what I ment smart ass, you have 127 to the crank then you do the mathamatics for horsepower loss to the wheels, 15% or so, that nocks you down to about 100-105 to the wheels, now back to your figgure of 135. . . do the math im not trying to be a dick head or a smarts ass, It was more of joking, but everyone takes comments there own way right.
    and im goingt o agree with phyregod, if you didnt break in the clutch properly you probably cause it
  12. WhatsAClutch?
    Maryland
    yea maual newbie??? you dont know anything about me what gives you the right to call me that??? as for the other comments looks like we had a misunderstanding no hard feelings. i do however want a little stiffer clutch you know, something a little more heavy duty, so i guess i should go with the OE Exedy. yea and the grinding issue, is not from forcing it into gear.
  13. ep3moschini
    Northbridge Ma
    the Exedy OE clutch can handel more power than stock, with a stock feel
  14. WhatsAClutch?
    Maryland
    i see they also have a stage one clutch maybe i should get that
  15. ep3moschini
    Northbridge Ma
    Im goingt o suggest that, its same as stock but it can handel like 40% more over stock
  16. WhatsAClutch?
    Maryland
    its not third gear dumass its 5th gear its not a loud grind either its kinda a quiet subtle one
    ive been drivin a stick for almost 2 years
  17. WhatsAClutch?
    Maryland
    yea what the fuck is ur deal man get off my case. thats what iwant cuz maybe down the road sometime i will get some more power upgrades u idiot did u ever think of that??
    oh youve been driving a stick since i was three big fucking deal dude what does that have to do with me buying a new clutch?
  18. WhatsAClutch?
    Maryland
    well in that quote is says they fixed it..... what i didnt tell u was that that time it was the third gear syncro that went out u have no idea what ur talking about, stop being so immature, im not gonna play the name game with you all day.
    im a ricer how so, because i had a valid question? or is it the fact that im 17? how old are you? hmmm... well whatever
    if somebody could give me some info on the stage 1 clutch that isnt borderline retarded like blanco that would be nice
  19. ziggi20
    ziggi20 New Member
    O.town
    MAYBE ITS YOUR ROOKIE SHIFTING ever thought of that one... how long have you been driving manual cars, blanco has some very good points for rookie drivers
  20. WhatsAClutch?
    Maryland
    yeah i have thought of that didnt u read all of the other posts...
    i hate fucking stupid people
    plus the main issue isnt about shifting its starting off some people i swear...
