most cable these days is rated at 3000MHz. The color on the inside of the male connector on the ground block needs to not be clear. Blue is the most common color for high frequency rated ground blocks.
Cable internet still runs at a lower frequency, generally speaking it doesn't exceed 1000MHz. Satellite tv signals run up as high as 2850 MHz between dish and set top box. Most of those surge protectors with the coax cause more problems than they save. I wouldn't bother.
Even a properly grounded cable or satellite system will be overwhelmed by a lightning strike.
